RodPickett Posted December 4, 2020 Posted December 4, 2020 How to install a leather drive belt on an Edison triumph cylinder phonograph 7
RichardLee Posted December 4, 2020 Posted December 4, 2020 Excellent instructional video! I have a standard model B that needs a new belt. Thanks for the tips.
Guest Posted December 6, 2020 Posted December 6, 2020 This is a skill that is a great introductory skill for people wanting to repair phonographs since it is the one thing that usually stands in the way of getting one to run.
jimmy47 Posted April 24, 2021 Posted April 24, 2021 I echo RichardLee; excellent instructional video.
Valecnik Posted September 7, 2021 Posted September 7, 2021 I found/watched this video or possibly another like it from Wyatt some time back. He made it so simple that even I could figure it out.
melvind Posted September 8, 2021 Posted September 8, 2021 Wyatt's videos are excellent. I am glad this one is on the forum!
Neilvanstem Posted September 10, 2021 Posted September 10, 2021 Great video with ideas I never thought of. I have only once changed a belt as I was waiting for the new belt to arrive. Well what I used (an old belt split) worked so well I never used the new belting material when it arrived. Now I see where I might have done a better job. Thanks so much for posting this. Neil
phono-phan Posted November 12, 2022 Posted November 12, 2022 On 12/4/2020 at 2:50 PM, RodPickett said: How to install a leather drive belt on an Edison triumph cylinder phonograph I tried the link to the leather drive belt file and it doesn't come up. What am I doing wrong?
RodPickett Posted November 12, 2022 Author Posted November 12, 2022 You are doing nothing wrong. I did. We moved Server files and I forgot to move this one. It is now restored. Thank you for the alert.
MisterJive47 Posted January 15, 2023 Posted January 15, 2023 Wyatt is fantastic at the art of restoring our machines. Just got an Orthophonic reproducer rebuild from him. Can't get enough of listening to it now. The only thing with his method on belts that I personally would differ with (just my own results) is I found that Loctite GEL Superglue works fantastic for fusing that lap on the belt as well. This cyanoacrylate has elastic properties to its polymer that allow it to be used even on rubber and has a good shear strength. I've done a couple of Standard belts with this glue with great results, and less concern for the cure time.
jimmy47 Posted November 3, 2025 Posted November 3, 2025 One of the things I learned after doing my first belt was to always vice grip the top splice and not the bottom one. I did it in reverse, and it pulled slightly apart. The belt works, but it is slightly ugly-looking. Wyatt does make it look easy, but I found that if you follow the video, it works just fine. My Columbia A now has a belt.
