Skip to content
View in the app
A Meltrope question
Featured Replies
I'm wondering if there is something I can do with this Meltrope III soundbox. It doesn't really sound much better than the exhibition on an open horn HMV machine I use. To me it looks like everything is in order, no damage to the diaphragm, the ball bearings are in place and the rubber is supple enough. Am I missing something? I expected a notable difference to a 1913 exhibition...
Greatful for thoughts!
Edited by Hogan
One picture too many
Which rubber is "supple enough," around the diaphragm or the isolator?  Ideally both should be, but the latter is critical for Meltropes (see below momentarily...).  The rubber should compress and spring back to form (i.e., you want "bounce" not "squish").
Are you playing electric process recordings when comparing?  Try 1930s recordings (or later) if you haven't already.
Have you "tuned" the isolator while fitted to the tonearm?  This can be done by adjusting the compression (via the knurled nut) and adjusting the position on the arm.
From the installation instructions:
Quote
The tone of the soundbox can be varied by adjusting the tightness of the knurled nut, thus controlling the flexibility of soundbox on tone arm; also by sliding soundbox on tone arm in a longitudinal direction in different positions.
  • Author
Thanks!!! That's exactly what I needed to know. All the rubber is supple, isolator and diaphragm - so I'll have a go at tuning it according to the instructions!
And yes. I've played all kinds of records - I'll be back when I hear what happens after trying the "tuning"!!
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
