Automatic Brake Alignment
IMG_1513.thumb.JPG.000d51c4c43029235c35765841871668.JPGOK this is where I show my ignorance.   First, I can't get the image to rotate to the proper orientation. But even worse, I have a feeling that the brake leather is supposed to press up against the inside of the turntable, not below it, correct?
I used 5mm leather cord and it was NOT easy to get into that claw.
You are correct - - when activated, the brake leather should be contacting the inner surface of the turntable rim.  You can slightly bend the brake arm upwards to achieve this.
Inserting/removing the leather is much easier if each "finger" is slightly bent away from the other, as in the motion made by "letting your fingers do the walking..."
