Hand crank cylinder phonograph.
Oceanlinerfanatic191
A few days ago while building a tinfoil phono I got a strange idea.
Would it be possible to make a hand crank cylinder player. It would be just like a tinfoil phono but instead of using tinfoil you use a cylinder.
You could install a reproducer to "float" along the groves so you could play black the record. This would not be meant to record on, just playback. Keep in mind this is just a thought but has anyone actually built one of these?
